964 Forum 1989-1994
2 strange noises and a warning light to sort
Old Apr 6, 2012 | 01:59 PM
l.chadburn's Avatar
l.chadburn
Default 2 strange noises and a warning light to sort
I took the car (1992 C4 cab) for a spin the other night and it started to make 2 strange noises.
The first is when I hit a bump in the road. I am running 18" wheels on lowering springs and at firsth thought it may be some rubbing, but cant see any sign of that. It lasts about 1 to 2 seconds and sounds like a cross between the noise you get when your tuning a radio in and someone scrapoing their nails down some sandpaper - KRRRRRRR.
The second noise can be heard when I take my foot off the gas (whether in gear or not). It is coming from the tunnel area. It is a wirring sound a bit like a worn bearing sound. Also when I move the gear stick around in neutral it changes the pitch of the noise - could this be a gearbox issue or maybe lack of oil in there?
I have booked it in my local Porsche Specialist on Tuesday but any suggestions would be appreciated.
Finally the warning light is on and does not go off until the switch is pressed.
There are no other warning lights on at all.
regards Lee
Old Apr 6, 2012 | 05:47 PM
John Boggiano's Avatar
John Boggiano
Lifetime Member
Warning light... Do all your warning lights come on with the ignition? You could have a dead or missing bulb that's trying to tell you something.
Old Apr 6, 2012 | 06:40 PM
l.chadburn's Avatar
l.chadburn
cheers John
High beam near side has gone
Will sort that and recheck warning light
lee
Old Apr 6, 2012 | 06:41 PM
Makmov's Avatar
Makmov
That means there is a fault and some probably pulled the bulb out of the dial.
Just turn it to the on position and see what lights up and what is missing. There should be a bunch lighted.
I looked at a car last year that almost all the bulbs were missing.
