964 Forum 1989-1994
Throttle response
Old Apr 6, 2012 | 12:23 AM
fogcity123's Avatar
fogcity123
Default Throttle response
I had an issue where the throttle cable came loose from the pedal cluster and after I screwed it back in, it seems like it doesn't "snap back" like it used to. It idles okay, doesn't seem like its pulling when I'm not giving it gas, but just feels off. Especially when I'm blipping it to downshift. Not as crisp. Any ideas?
Old Apr 6, 2012 | 06:57 AM
ras62's Avatar
ras62
You should check to see the idle switch is being operated, obviously with no pressure on the accelerator, then get someone to fully press the accelerator and check to see the wide open throttle micro switch is being operated correctly. Usually it will operate about 70% throttle. Without WOT switch the DME mapping will not give the full performance.
Old Apr 7, 2012 | 12:38 AM
fogcity123's Avatar
fogcity123
I'll try that. Thanks.
