Cup wheels Part numbers and off sets
Do these seem correct ?
7- 55 front 8-52 rear next to the tyre valve
And if so does anyone know what part numbers would be
Great info thanks
If the original factory fitted 16" cups were front 6j and the rears 7j. Then when fitting 17" cups would you not want to fit rears with an equal increment/stagger, there by fitting 9j when the fronts are 7j ?
RS ran 7.5 & 9.0
Widest standard rear from the factory on a narrow bodied C2/4 was 8.0 (with 7.0 front)
Just looked in Enthusiasts companion by Adrian Streather and the 17" 9j wheels with offset 55 appear to be approved for the 964. So presumably these are ok to fit? (spacers not required)
Thanks for the info guys
The seller is being a **** as he wont give me the part numbers and just replied 'there are lots of numbers on the back of the wheel 'and 'my porsche expert tells me they are genuine ' I will give them a miss
Some just some monkey trying to make a fast few ££, not knowing if they are real or not
That RSA page says a common mod for the RSA was to put the 8 inch wheels up front and run the 9 inch wheels in the rear.
Can any narrow body 964 that already runs cup 7 and 8 inch wheels do this with no spacer? and if so, what tire sizes would you use? I imagine you would be more that a 225 width up front then...
