Which 928 front rotors fit with 964 RS brake setup?
All, I'm looking for the 928 PN's that can be used on a 964 with an RS brake setup. The reason I'm looking is I want the ones that are not cross drilled and from what I've been told the 928 rotors will fit the bill.
Thanks in advance, James
Sorry, can't help you there. Here are the 964 Turbo part numbers (drilled):
Front Rotors:
965-351-045-00
965-351-046-00
Front Rotors:
965-351-045-00
965-351-046-00
Cheers, James
No i think there is only one type.
928 351 046 01
928 351 045 01
Factory ones are plain.
If you search in the 928 section someone sells a two peice rotor.
Disc Brakes Australia do a slotted rotor if that's your thing.
PS for goodness sake check the fitment when you buy dont just take my word for it!
928 351 046 01
928 351 045 01
the only ones I've ever seen are the 928GTS and the 964t(both 3.3t and 3.6t), these are all drilled
the 928S4 used the 304x32mm rotor which is not drilled but these use the calipers which are 964RS sized but that don't have the 964RS/964t raised mounting bosses. These calipers use the same pads as the 964RS and 964t but use a less broad rotor because of the lack of raised mounting boss and were used on 993 front and 928S4.
So you need to carefully determine which front caliper you have before purchasing
the possibilities are
Big Red which was used on 993tt/RS front, 964 3.6t front and a black version which was used on 928GTS these all need 322x32mm rotors and a 132x58mm pad
the slimmer version of the Big Red w/ raised mounting bosses aka Big Red light, these were all black used on 964RS front, 964 3.3t front, these need 322x32mm rotors and a 132x48mm pad
the slimmer version of the Big Red w/o raised mounting bosses aka Big Red light, used on 993(black or silver) front, 928S4(black) front, these need 304x32mm rotors and a 132x48mm pad but can be used on 322 when spaced out away from the axle
be careful to get rotors w/ 964 o/s if you have 964 wheel carriers and 993 o/s if you have 993 wheel carriers
Without wishing to hijack, can anyone (Bill ??) confirm the difference between the 964 3.3T and 3.6T front discs ? I am led to believe that they are the same size and offset, but the pad contact area is bigger on the 3.6T disc.
For some reason the 3.6T disc seems to be cheaper to buy, so if the dimensions are the same then this will be a cheaper alternative for my RS.
thanks,
Jamie
thanks,
Jamie
