Rough idle problem - ideas? (with video)
Hi guys,
I am having trouble with a rough idle. It idles fine when cold, however when hot it sounds uneven.
Here is a video showing cold and hot idle
The car never cuts out and pulls nicely under load.
I have cleaned the ISV and I have let the car sit for an hour without the DME relay. I have also let the car sit for 15min without battery.
Any ideas?
Any ideas?
Sounds to me like the cylinder head team sensor may be faulty. If it runs well cold but not warm. Do you have access to a scantool or hammer? Are there any codes? And just to eliminate the ignition side, check your distributor cap, rotors and belt.
