Airbox Holes
Airbox Holes
OK i know that drilling holes in the airbox is done for sound and not performace (i have race cans on my motorbikes purely for sound :-) ), but are there any downsides to doing this.
Also where do i drill them and what size?
Cheers
Simon
Cheers
Simon
The only downside I can think of is that you are likely to fail noise tests at trackdays, for this reason I took the cone filter off that a previous owner fitted to my car. Also, if you change your mind and want to go back to an undrilled cover, buying a new box is expensive!
I'm sure that if you ask around - someone with holes that doesnt want the holes will trade with you...
I wish you were in the states - I'd trade for my holed box cover. I'd love to see what the difference is. Mine was drilled when I got it.
That's the biggest negative....you or the next buyer might perfer a stock air box cover.
Appearance aside, there are few negatives about the noise.
Mine has been drilled for a couple of years so I can't compare to stock anymore, but the level is subdued (but slightly louder) at part throttle. A holed air box cover is definitely a lot louder at full throttle or above 4,000 RPM. Sounds like a roar!
My car is completely stock and I've never heard the drilled air cover before. Is the increased sound only in the cabin or does it also change the sound at the tail pipe. Thanks.
RL Technical Advisor
While I'm unable to address this modification on other vehicles, I can tell you that adding 5-6, 2" holes to the airbox cover is worth 2-3 BHP.
While not noticeable, its certainly measurable in back-to-back dyno testing so IMHO, its worthwhile doing in the pursuit of more performance.
Sounds nice, too.
Burgled
Take the front cover off and duct tape the air filter on and drive it and see if you like it. Make sure the seal is good on the edges to keep sand from getting in.
One answer to your query would be to look out for a drilled airbox on ebay as I did. So now I have both drilled and stock airboxes. I can recommend using the drilled one for a better, deeper roar! Good luck. Brian.
Hi Simon,
Sounds nice, too.
Sounds nice, too.
Cheers
Simon
I recommend having both. The second complete airbox cost me me maybe $75US. The only downside is I tend to "gas" it a little more to hear the nicer engine sound.
I have a drillled airbox I would like to change for a non drilled one! I am in oxford too so just up the road ;-) can you hang fire and maybe we could meet up to see if a swop would save both of us some time and effort??
regards
Martin
p.s. have pm'd you my contact number so drop me a txt if a possible swop is of interest.
