Shifter boot replacement.
Anyone who has ever pulled off the (hard rubber?) **** assembly from the metal shift shaft? I'm not Conan, but no weakling either, but abandoned the attempt once already in fear of breaking assembly below, or knocking my front teeth out or worse when the it finally "lets go". Any hints to success would help give me the courage to give it another shot, and be highly appreciated. THANX.
Formerly turbotwoshoes
Lift the skirt and look?
If I am not mistaken, there was a model change on shifter boots. On some, and I can't remember the years, you have to pull the skirt up as high as you can and loosen a set screw? I would look first before I give it the heave-ho. Just a thought.
My shift ****/boot is out of a '94, and there is no set screw, nor any hole for a set screw to go in...but, as others said, worth a look?
I believe some of the later 993/996 shifters have a set screw.
The edge of the shift boot you mean? You have to push down until it unclips, then angle the rectangular frame and pull it out.
Sorry to keep essentially hijacking everyone else's threads - but quick note on a Shift boot...
A few months back there was a thread about the Cashmere Beige Shift boots- and limited availability - there were four remaining at the factory for original cashmere beige boots for our cars. I got the last one of those four through Susnet. I subsequently bought a Weighted boot and am waiting for that to arrive.
If anyone needs/wants the original brand new cashemere beige boot, I'll likey have it available for what i paid... Jst throwing it out there...PM me or grab the other thread and we can discuss there, just that this thread made me think about it....
