Brake pad Vibration Damper Question.
There are no vibration dampers installed on any of the pistons, there are however some fiber pads glued to the back of the existing brake pads.
I ordered replacement Textar brand pads (which appear to have the same fiber pads glued to them), as well as new OEM rotors, and wear sensors.
My question is t, are the fiber pads glued to the back of the brake pad sufficient to eliminate the squeeking, or do I need to install the 36 and 40 mm vibration dampers as well. It seems odd that I would need both, but I was hoping that someone here could provide guidance.
Thanks in advance
By the way, this car is used a driver, no track use, and the existing front pads just started squeeling in the last 1000 miles. It is quite irritating and I need to assure the problem is eliminted. I have done a search, and read all I could find on the subject.
Dave
The last pads I used had a kind of metal shim glued on the back of them. I just smeared a bit of copper grease on those.
No squeeling.
I do have some Wurth copper paste in stock, but the 964 shop manual (section 46-2) says....
"Pad Backplates (Backs of brake pads) must not be lubricated with grease"
I am not all that big on adhearing to rules, but that statement does concern me.
The manual does go on to say...
"In order to prevent siezure of brake pads in the brake calipers due to corrosion, give the seating and guiding surfaces a thin coat of grease."
This statement appears to be referring to the edges of the pads that slide into the caliper.
Dave
Bedding your brakes
No need to lubricate anything. Here is a description:
Changing Brake Pads
