Alternatives to Optima Battery?
My Optima 35 Red Top is dead (won't hold a charge, even when disconnected) after 2 years of service. This one was a warranty replacement for another Red Top, which also only lasted 2 years. Before that I had a Yellow Top, which also died after 2 years. Before that an Interstate, that lasted 5 years, but it puked some of its juice out at the end.
In fairness to Optima I only drive the car once every week or two, with occasionally a month passing, but, still, I think I should get a bit more life out of the batteries. (I do have a C-tek.)
What other alternatives are there out there for the Optima? I would like to get a battery that is "sealed", AGM or otherwise...it just feels "cleaner", at least.
Have you tried to charge the old red top the new way ?
Optima put out a two battery charging suggestion ,
one full battery hooked up to the dead optima and then a charger hooked to the good battery .
http://www.optimabatteries.com/produ...agmbattery.php
Have you had your charging system checked to make sure its working as it should ?
Anyway, the car started right up that procedure, no problems. I had it hooked to the C-Tek for 48 hours. After I drove it, I disconnected the battery ground to verify I didn't have a randomly occurring short somewhere (even though I am only measuring 40 mA drain). I reconnected it this morning, and only got a click from the solenoid. I can only conclude that the battery has an internal short. I've been through this routine twice now since Christmas.
You live in Texas, where it can get hot, very hot. Battery charge voltage is based on temperature.
Have you checked what your battery voltage is while driving the car?
Have you checked your battery voltage while charging the battery while it is parked?
It is possible that in both cases you are overcharging the battery.
And no matter what you do, a battery doesn't last as long when exposed to higher temperatures. I chose to go with a standard battery.
What voltage does it discharge to in 2 weeks?
Leaving the so-called "sealed" aspect aside, there really is very little reason to use an AGM battery.
AGM batteries have a few advantages; none of them of any importance to us. 1) they have very low internal resistance which provided the high CCA rating. Unless you are starting at well below sub-freezing temperatures, thats of little use. 2) they have a very low rate of self-discharge, but that only applies if you put the battery on a bench. When you have 20 mA or 40 mA devices draining your battery, the low rate of self-discharge is of little interest.
Your experience with Optimas is very similar to mine. 2 died prematurely, very disappointing.
I went back to a good ol' conventional battery from the corner NAPA.
No more battery problems.
1 Post
FWIW, I have an Optima Yellowtop in my banger Camry. It has been completely abused - used regularly for a while, then left completely discharged for months at a time, then recharged for daily driver duties, and over and over. 5 years on, it's still going!
The optima is sealed , its next to impossible to get acid out of it or to put water into it . You can mount an optima on its side without anything leaking out .
