964 Forum 1989-1994
Round plug behind clock?
Old Feb 11, 2012 | 08:24 PM
Mr.Spacely's Avatar
Mr.Spacely
Default Round plug behind clock?
I removed my clock today, and noticed a round female plug dangling behind it in the dash. It looked to have a jumper installed. Did some searching, but still can't figure out what is for.
Something to do with hvac, or a test port of some kind?
Old Feb 11, 2012 | 09:06 PM
Lemass Automotive's Avatar
Lemass Automotive
Aerial?
Old Feb 11, 2012 | 09:33 PM
Mr.Spacely's Avatar
Mr.Spacely
On closer inspection, it is a brown 15-pin connector of the same type and design as the clock connector. Only difference is it has a trapezoidal protrusion in the center, whereas the clock plug has a D-shaped protrusion. Three of the pins are blank, and I was mistaken about there being a jumper.
Old Feb 12, 2012 | 03:32 AM
Lemass Automotive
Well. Not an aerial then lol
Old Feb 12, 2012 | 11:04 AM
dfinnegan's Avatar
dfinnegan
There was an option for an electronic computer in the tach. Perhaps this is the alternate connector for that tach option.
Old Feb 12, 2012 | 02:35 PM
boxsey911's Avatar
boxsey911
Spot on. That's exactly what it is. When I fitted an OBC tach, I needed to unplug the old connector and plug that one in its place.
Old Feb 12, 2012 | 03:20 PM
Lemass Automotive
Hmm fitting the 993 rev counter did cross my mind
Old Feb 12, 2012 | 03:26 PM
Makmov's Avatar
Makmov
I took my clock out, too. Haven't noticed any such animal like that.
In any event, whohoo fixed my Airbag light. Indeed it was a clock circut board failure. On of the pins to be exact. Tested it good circut from the socket to the solder but interestingly the pin itself was dead as a door nail resoldered all the joints working for now.
Old Feb 12, 2012 | 05:08 PM
g60pops's Avatar
g60pops
let me know if you need a control stalk and obc rev counter
Old Feb 12, 2012 | 05:37 PM
Mr.Spacely's Avatar
Mr.Spacely
Mystery solved then, I was worried it might be important.
I just found 4 bad solder joints on my clock and fixed them. None was connected to the airbag light, but maybe it was causing some other mojo. Fingers crossed.
Old Feb 12, 2012 | 06:00 PM
Lemass Automotive
