turn signal + high beam
Hi all,
A little while ago my high beam decided to not turn on anymore, then last week my indicators stopped indicating!
The hazard lights come on ok, so I was just about to tackle the turn signal assembly via this https://rennlist.com/forums/2772527-post1.html
but cant see a part number for it, nor can I find one on Pelican.
Also, the turn signal relay might be worth checking too, if I knew where the heck it was!
Can anyone help?
Cheers
AB
Can anyone help?
Cheers
AB
Thanks for the link, but after pulling the steering wheel off and removing the plastic surround, I found the plug at the back of the turn signal had worked itself slightly loose - pushed it in, tested, all working again !
Cheers
Cheers
