Exhaust manifold removal question.
Hi, all
I am in the process of removing my driver side exhaust manifold for assessing to an oil line I am replacing. I was able to remove the hex bolts that go through the manifold / heat exchanger assy. But I cannot get the regular nuts off with a standard 13mm socket with swivel or a 13mm wrench. Is there a tool I need or do any of you have a trick for this.
Thanks in advance,
Steve
Thanks in advance,
Steve
The best tool for that job is a "Swivel-Socket end wrench" you can buy them either double end or combination. Have a look on the net, Snap On makes a nice one but you pay through your nose, so find a supplier with reasonable prices.
I have the opposite issue - one of the hex barrel nuts completely rounded out. Looking through the hole in the manifold, it appears the exhaust stud is a tad long and I guess there was not a lot of surface area for the allen wrench (sir tools P243) to grab.
I have sprayed it several times with PB blaster, but at the moment, I am at a loss as to what to try next. The nut in question is on the left side, flywheel end - IMHO the most inaccessible nut on the car.
Suggestions?
Suggestions?
This is what I use with an extension. A socket swivel combo which has a shallow socket head.
this was the best for me too.
i used cans of Liquid Wrench let it soak over night
i would reverse drill the Allans out
Suggestions?
Suggestions?
If interested, here is how I got the allen nut off:
I used a center punch to put a mark on the side of the nut
I took a long ~0.5cm bit and drilled through the nut into the stud
Using a long flat head screwdriver and a hammer, I tapped on the side of the hole and got the nut to move almost 1/2 a turn
Enough of the socket was exposed to use the allen wrench to remove
Success. Exhaust off - now to replace the stud
