964 Forum 1989-1994
Test for cracks in the case?
Old Nov 29, 2011 | 11:43 PM
Metal Guru's Avatar
Metal Guru
Originally Posted by Indycam
if you look close enough at any part you will find flaws , that the trick is knowing what flaws are acceptable and what flaws are not .
Agreed. The non-destructive testing (NDT) industry is dedicated to the detection of flaws and the prediction of service life. The aircraft industry is the NDT industry's biggest customer.
However, I think comparing an aluminum engine crankcase for an aircraft to an aluminum crankcase for a car is an apples to oranges comparison.
The aircraft crankcase must be much lighter. It is therefore thinner. Aircraft owners and operators expect to re-engine their aircraft at some point during the service life of the aircraft.
This is not the design philosophy of a car. The engine is more robust and expected to outlive the chassis. Since warranty costs and customer satisfaction are at stake, engine designs endure punishing testing to insure that they meet this goal.
Old Nov 30, 2011 | 11:42 AM
FeralComprehension's Avatar
FeralComprehension
Originally Posted by August West
With a leak of 4-5 inch puddle per day and leading up to a two foot puddle over a couple of days, I'd find it hard to believe it would be coming from a crack in the case that noone can seem to be able to find.
August, you meant "Without, right?
Old Nov 30, 2011 | 11:49 AM
Indycam's Avatar
Indycam
Its apples to apples .
This is a guess on your part ?
You think continental / lycoming would make , get approval for and sell cases that crack so they could save a few pounds ?
You think continental / lycoming would accept engine case failure for a few pounds ?
Not really .
I think you have that backwards , the aircraft engine must be more robust and reliable , lives depend on it .
When the Porsche flat six was used as an aircraft motor it needed to be fixed up to be more robust and reliable for lives depended on it not failing in flight .
http://www.seqair.com/Other/PFM/PorschePFM.html
You think the auto industry has "warranty costs and customer satisfaction..." and the aircraft industry doesn't ?
http://dedeporsche.posterous.com/fro...gines-that-fly
"The Porsche FlugMotoren (Porsche Aero Engines) was either sort of a disaster, or a total disaster, depending on who you ask."
"Under United States law, where most of the engines were used, Porsche was required to continue to supply parts and maintenance for the engines. Instead, they claimed to have destroyed all spare parts and refuse to support the very engines they put into the marketplace. The company has even gone so far as to try and render the planes worthless by claiming the engines need certain parts replaced after a number of flight hours and then refusing to provide technical information so such parts could be privately manufactured."
Old Nov 30, 2011 | 12:24 PM
Makmov's Avatar
Makmov
The Porsche Mooney, pretty much just came down to initial cost to build and maint. cost of ownership, so it didn't fly, pardon the pun.
There was more going on there under the radar and was some infighting about the whole project.
So Porsche did what Porsche does and took their football and went home when it doesn't go their way.
Old Nov 30, 2011 | 01:25 PM
cobalt's Avatar
cobalt
http://www.lightplane-maintenance.com/LPM_LPM_0605.html
"While we will agree some cases seem more crack-prone than others, no engine is immune. Both Lycoming and Continental discuss crankcase cracking at length in service literature, understanding that it can happen and with some frequency.
Both publish guidelines for inspecting cases and offer advice on what is considered airworthy and what isn't. Some publications provide repair criteria to be used during overhaul that severely restrict where welding and re-machining of the case may be accomplished."
"Crankcases crack because aluminum castings do not like to flex and air-cooled engines equipped with opposing cylinders flex as a matter of operational functioning. The result is predictable as the case relieves normal and abnormal stresses."
My father was a prototype machinist for Hughes Aircraft , he tells me that every piece of metal is flawed from the get go and more so after it has been machined as most machining rips metal from metal . Every cut surface has micro cracks resulting from the cutting . He has told me that if you look close enough at any part you will find flaws , that the trick is knowing what flaws are acceptable and what flaws are not .
A bigger reason why aircraft cases crack over a similar car engine does not have to do as much with flex as much as it does with expansion and contraction due to temperature variations associated with aircraft. Car engines will get hot or cold but stay within their ambient temperature while operating. An aircraft engine might leave the ground at an ambient temp of 80 degrees F and then be put through all sorts of temperature changes in a few seconds or minutes time. Temps may drop to as low as -30 or more and then jump back to 80 when landing. the sudden change in temperature can impact a casting tremendously. This can also change the temper of the alloy depending on what it goes through.
Established criteria is used to determine what is acceptable surface defect we also have to consider surface irregularities which are common in castings which may or may not have an impact. What is a stress riser depends on its application, alloy used and location of the indication to an outer edge or a highly stressed part of the casting.
My understanding of aluminum and magnesium castings is somewhat extensive and I can assure you odds are if his case is cracked it is more the result of bad practices from previous mechanics than it is from flexing.
Old Nov 30, 2011 | 01:58 PM
August West's Avatar
August West
Nah, I meant "with." I gleaned from porschefan's other postings that he was getting a 4-5 inch puddle per day, spreading to a two foot puddle after a few days. It seemed to me that a miniscule crack that noone has been able to locate wouldn't be big enough to leak that much oil and that the oil leak is probably coming from somewhere else.
Sorry if my words were confusing! I was just making a case for the simplest solution usually being the right solution as per Occam's Razor.
Old Nov 30, 2011 | 03:42 PM
FeralComprehension
Thanks for clarifying; looking at the photos in the other current thread I had no idea the problem was as severe as that.
Old Nov 30, 2011 | 06:44 PM
Metal Guru's Avatar
Metal Guru
Well that's a convincing argument!
Yes they would.
To make something lighter you have to remove mass.
Aircraft manufacturers go to obsessive lengths to save weight. Special lightweight upholstery and 3 phase power are two good examples of this. Product design and manufacturing are full of trade-offs. Some durability had to be traded for weight.
Well, that's why aircraft have to be inspected at set intervals and engines overhauled on a schedule too. Think of what it would be like if airplanes were maintained like cars?
Interpretation: Porsche had excess manufacturing capacity for 911 engines. Some suit in Wiessach got the bright idea to engineer and build 911 aircraft engines. The due diligence wasn't performed up front and down the road Porsche got a nasty surprise. They found out they had to supply parts long after they were accustomed to doing and that there are a ton of third party manufacturers and re-manufacturers, not to mention repair/overhaul businesses they would have to be responsible for. In the end, it was a big money loser so Porsche pulled out.
Old Nov 30, 2011 | 07:03 PM
mojorizing's Avatar
mojorizing
With the engine now out of the car, I have a suggestion on how to possibly locating porosity/crack in the case. This method is used in large tanks where it's not possible to put a hydro test on a small repair on a steel bulkhead. A vacuum is applied to the area by the use of a "vacuum box" that has a window to see the weld repair ( that's been soaped up) to be tested. To do an engine case, all you would need to do is clean the area, then use the same vacuum bagging techniques used in boat and surfboard construction to apply a deep vacuum on the suspected area. Let stand for awhile, then remove vac bag to see if there's oil residual drawn out of the casing. Unless the crack is in the vicinity of an oil passage where the pressure differential is 5bar, a vacuum should be sufficient to draw oil from a crack that normally leaks at static pressure.
Unless you prove your mechanic wrong, you won't have piece of mind until you replace the casing.......
As an aside, in the past, did you jack the car by lifting on the engine seam?
Old Dec 1, 2011 | 10:28 AM
cobalt's Avatar
cobalt
This is not an approved technique to lifting a 964 and is a definite no no. However people do it all the time and I have never heard of anyone cracking a case by doing so although blowing out your engine mounts is quite common.
I am curious to see what the results are and if and where they determined a crack to be.
Old Jan 15, 2012 | 05:54 PM
Indycam's Avatar
Indycam
Kevin Cameron has a great article "Casting Chronicles" about casting cases .
Page 24 Cycle World , Feb 2012 .
He also has a great article "Hot Metal" about heat flow in an air cooled heads
Page 38 May 2011
Old Jan 15, 2012 | 09:19 PM
jody stowitts's Avatar
jody stowitts
Thumbs down
Take the advice of August West. Think someone(s) headed in the wrong direction!
