Does 964 C2 have a starter relay
Notice that the fuse panel shows a starter relay, I have a early 90/C2 manual tranny and turning the key does nothing, all dash lights come on and dont blink or dim when key is turned...starter/solenoid does not click or do anything..I am going to replace the starter which was exhibiting failure to engage when hot and hopefully that will take care of this ...is there anything else that may cause this
Oracle I dont think thats it, starter has been acting up and failing to engage, I did add a hot start relay kit which helped a bit, Wiii post results after I tackle the R&R of starter..
Brand new Bosch starter installed (gee that top nut only took 4 hours to remove!)
Still no start, car runs fine if I pop start it and there is power going to starter bridged the solenoid to main lead and starter is fine
I think the combination of a dying starter was too much for the 21 year old ignition switch and it gave out so...
Next step is Ignition switch electrical portion......
Anybody have any other idea?
IHI KING!
Before tearing apart your ignition switch, try to isolate the problem. When someone turns the key to start, are you getting power to the starter solenoid? If yes, then the problem is the starter or grounds. If not, then trace the wire back to see if you have a break.
Well it isnt the ignition switch, I replaced that...since starter works when I bridge the 12 v lead to the soleniod I guess somehow I have a bad 12v supply line to the solenoid
Funny thing...i was having starter issues and band aided it by putting in a hot start relay,,i took that out of the system but still no start..It was acting extremely unruly about starting (starter would spin but not engage and sometimes just clicked...especially when hot) so I cleaned some relay contacts thus my question about starter relay on fusebox, I changed out the DME and that didnt help
