Personal/Nardi steering wheel
I'm curious if anyone has fitted a Personal or Nardi steering wheel to their 964 with an original airbag. I've searched and searched but come up with nothing. I see momo's but nothing about Personal or Nardi.
I've got the airbag resistor taken care of but now that I've put the hub adapter on it seems that it wants to crush the the black plastic clam shell surrounding the wiper/turn signal switches. I've checked the parts and they all seem to be the right numbers, just wondering if anyone has run into this before or had any advice.
Hi , I fitted a momo wheel to my 964 and had to enlarge the steering column cowls , the newer momo steering wheel hubs are slightly larger than the old ones I believe .
Thanks for the info, is that all you had to do? Do you have any pics you can email me or post here so I can see exactly what you did. I'm also having trouble seeing how the horn will actually work after removing the clock spring. Thanks for the responce
