964 Forum 1989-1994
Do you use anti-seize?
Old Oct 16, 2011 | 07:38 PM
Jacke2c's Avatar
Jacke2c
Formerly turbotwoshoes
Default Do you use anti-seize?
Do you use anti-sieze on your spark plugs when installing new?
Old Oct 16, 2011 | 09:15 PM
Jon Hansen's Avatar
Jon Hansen
I do, but just a very small dab. I have never had a problem.
Old Oct 16, 2011 | 09:26 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Absolutely. Never any issues after 45+ years of such practices in all kinds of engines.
Old Oct 16, 2011 | 09:43 PM
Jacke2c's Avatar
Jacke2c
Default Annual tune
Thanks for the feedback. I just spent several hours tearing things down for what should have been an "easy" tune up and valve adjustment. 9 out of 12 sparkplugs were really tough coming out. I chased all the threads this afternoon and had a few small metal flakes come out. In my oil field days we always used anti-seize when making-up dis-similar metals (aluminum and stainless). I was beginning to fear I was going to twist a plug off or strip the threads. They all cleaned up nice, but wanted to insure I did not have this problem again (first tune-up on this engine). As a side not, this engines internals look great and fresh....
Setting the valves tomorrow night and bolting it back together.
Thanks for the advice...yes a small dab will do you!
Old Oct 16, 2011 | 09:48 PM
Babalouie's Avatar
Babalouie
Will just the regular nickel anti-seize be good, Steve?
http://www.permatex.com/products/Aut..._Lubricant.htm
Old Oct 17, 2011 | 04:30 AM
There are three different types of anti-seize:
1) Aluminum-based (this is the Permatex stuff you are looking at)
2) Copper-based (best choice for plugs and most exhaust applications
3) Nickel-based (best choice for extremely high heat apps such as turbocharged engine exhausts)
Copper stuff for you.
Old Oct 17, 2011 | 05:17 AM
Babalouie's Avatar
Babalouie
Cheers
Old Oct 17, 2011 | 11:51 PM
IXLR8's Avatar
IXLR8
Originally Posted by turbotwoshoes
Do you use anti-seize on your spark plugs when installing new?
Always. I place a thin coat on the threads using a small paintbrush.
I use Liqui Moly Kupfer Paste (copper paste).
Old Oct 18, 2011 | 01:06 AM
AOW162435's Avatar
AOW162435
Seared
Originally Posted by IXLR8
Always. I place a thin coat on the threads.
+1.
Andreas
Old Oct 18, 2011 | 09:36 AM
IXLR8's Avatar
IXLR8
Originally Posted by AOW162435
+1.
Andreas
Also on all exhaust fasteners. I replaced all fasteners when I had the whole exhaust system off and applied a coat to all the threads. It beats having to struggle with a seized fastener or worse yet, a snapped off stud.
