Need help with Varioram Conversion
I am about to install a varioram intake on my 1995 993 motor which unfortunately has a 1993 inductionsystem. the varioram intake is missing the ISV and the fuel rails.
1) Will the 964 ISV work on the varioram instake? The parts numbers are different. I am running a Motec M48 Engine Management.
2) Will the fuel rails from my 964 induction system bolt up to the varioram intake?
Thanks Mark
P.S. I have read almost every post concerning these issues but could not come up with an answer.
Thanks Mark
Mark -
I have put a varioram from a 993 on my 964 - but John has put a varioram on his 993, he has pub a full detail on what he did - do a search and I am sure you will find it
I used my ISV with no issues and I used my fuel rails with no issue - issue is in the connecting hoses, You will need to set Motec up to control the varioram at 5200RPM and 5800 RPM -
If you need more detail let me know
Not John - Correction - Joe
Go to VRAM Conversion DIY: http://forums.rennlist.com/rennforum...ferrerid=21390
Just greatest article / DIY pub on the conversion
