Storing cams
Super Duper Moderator
Hey all,
I searched so don't berate me.
I have a set of after-market cams I want to store for at least a year - aside from a light coat of oil to prevent surface rust, any other precautions I need to take? Seal them in a plastic bag or better to be be wrapped in oily rags? Is cold (-40 C) bad or should I go for heated storage (which is, of course, more humid)?
And what oil to coat them with - I searched elsewhere on the 'net and some say PB Blaster, others recommend WD-40 or even gear oil/ATF??
What's best?
What's best?
This is an un-educated opinion, but I'd hit them with WD-40 (as it's original purpose was as a wire dryer-version 40) then I'd coat them in a light oil, then store them wrapped in some kind of waxed kind of craft paper. I keep finding old parts like that in great condition after many years.
http://www.practical-sailor.com/issu...es/5502-1.html
"Our test lineup included Boeshield T-9, Corrosion Block, CorrosionPro Lube, CorrosionX, CRC Heavy Duty Corrosion Inhibitor, CRC QD, LPS 1, Strikehold, TC-11, WD-40. The TC-11 was our top pick."
http://www.tc-11.com/
http://boeshield.com/
I use the Boeshield T-9 , I use it on tools . I use it on my car .
Thanks guys - I think I'll use some waterproof grease I have after spraying with water-dispersal 40 (not wire dryer).
I think I'll skip the liquid argon (too cold).
Marc
Marc
http://www.tc-11.com/Marine%20Electronics%20Test.pdf
WD-40
"Bottom Line: It’s better than nothing, so no harm done when you use this on electrical, rather than electronic, equipment."
Boeshield T-9
"Bottom Line: For the one-stop shopper, this product has the best combined "score" for corrosion inhibition (PS April 2007) and electrical protection."
WD-40
Boeshield T-9
http://www.practical-sailor.com/issu...es/5431-1.html
http://www.mbcboats.com/FAQs/FAQ.htm...e_accumulation
"THE TEST
Each of the test products was applied to two mild steel strips—one to be suspended in salt water and the other to be sprayed with fresh water."
WD-40
"Bottom Line: Works well in fresh water—and makes no greater claims."
Boeshield T-9
"Bottom Line: In terms of what our test covered, T-9 works as advertised, even in salt water. Slightly more corrosion at the screw and price edged it out of the top three."
"THE TEST
WD-40
Boeshield T-9
