964 Forum 1989-1994
front caliper removal
Old Sep 6, 2011 | 11:32 AM
raoul's Avatar
raoul
Default front caliper removal
Hi all,
Does anyone know if i can remove my front calipers off the discs without disconnecting the brake line going into the back of the caliper as i have a busted bleed screw. It's a metal hose but i only need it to bend over a touch. I'm hoping it's flexible enough.
I'm doing this as i need to check my discs for warping as i'm getting slow speed judder on braking though i think also the hubs weren't cleaned properly when they were changed.
Old Sep 6, 2011 | 11:52 AM
Laker's Avatar
Laker
Hi Raoul,
Yes, you can carefully remove the calipers and hang them with ZipTies to the Spring, or in this case (with mud guard removed) Air Cond. line bracket.
Old Sep 6, 2011 | 06:40 PM
raoul's Avatar
raoul
Thanks mate, useful photo too. That's my next thing to do then. Just fitted a new oil thermostat......messy job, need to clear the driveway and garage floor first.
Old Sep 6, 2011 | 06:44 PM
ghhally's Avatar
ghhally
Check for jammed pads due to aluminum corrosion under sliding plates.
Old Sep 6, 2011 | 06:57 PM
KaiB's Avatar
KaiB
...and then run out and get a Girodisk piston spreader!
It's a joy to use a really good tool and the color is just right.
Old Sep 6, 2011 | 07:00 PM
boxsey911's Avatar
boxsey911
Raoul, you'll find there is a spring clip on the shock, where the metal line joins the flexible line. Remove that and then you can move and hang the caliper as shown in Laker's pic.
Old Sep 7, 2011 | 04:24 AM
raoul's Avatar
raoul
thanks again everyone.
plates are corroded underneath but have a pair of calipers i'm refurbing so will swap when they're ready but wanted to suss out the discs first as they're only 3000 miles old.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 11:24:30
