Cab top woes
effing thing would almost cause me to sell the cab and buy a turbo, but it's just swapping one problem for another... or so I tell myself.
the history- last year the driver's side frame snapped. My guess at the time was that one side's motor had failed, causing the unevenness and subsequent snap if the B pillar. Side has been repaired, and all the pieces back in the proper places. Now I'm trying to figure out what's not right.
What I do know, or have done.
1. Driver's side rear motor cable was short- did the cable fix by removing about _____ that much of the cable housing and wrapping it with tape.
2. Have all the bolts loose on the mid-car adjustments right by the B-pillar, in fact it's part of the B pillar mounting.
3. Have the bolts loose by the passenger side transmission loose to align the top.
4. The passenger side front motor won't unlock the top
5. I have no idea where to go from here.
6. Can someone post a picture of both left and right side transmissions and brackets going to the top? trying to figure out if mine is off.
Any ideas?
keywords: Cabriolet cable motor switch transmission
Any ideas?
I think I have it figured out, just not sure how to fix it. The gear in the transmission is only 1/2 a circle, and my gear has come off the track itself. I'm not sure where to restart the gear on the assembly so it's properly aligned.
I found this thread really helpful
http://forums.pelicanparts.com/porsc...sting-diy.html
Hope it helps.
Hope it helps.
it's not the electrical, it seems. The transmission is in the wrong spot, and now I've busted off one of the nuts that holds the trans to the body. 1 step forward, 3 back.
Easiest way I found was to remove both transmissions, dismantle them and set them both up at mid-point. Its not a difficult job but, to re-install them, you will need a "helper" to hold the raised hood in place (about vertical) while you reconnect the drive arms.
Because the quadrant gears will be at mid-position, it follows that the hood will need to be at mid position (ish) to reconnect the crank arm at each gearbox where the 19mm bolt is. The crank has a machined "key" to align them to the gearbox so they need to be right for tightening. The hood only needs to be positioned when reconnecting. When I did mine (a few years ago) I kept the hood closed (but unlatched) to give the best access to the gearboxes.
When I aligned my top after the cable started slipping, I closed the top completely (latched totally) with the transmissions disconnected from the top. Then I positioned the half moon gear in the transmission to the proper side of the gear on each side. Then attached the transmissions to the car and with a drill attached to the end of the transmission cable (the motor side) ran the drill back/forward until the cab top arm aligned with the slot in the transmission. Did the same for both sides and once aligned tightened the bolt/arm to the transmission.
Let me know if you have any questions, its been 2 years and I haven't had any issues, so I guess I aligned it properly.
