What exactly does the spoiler control module do?
I posted a while back about problems I am having with my spoiler on my 1990 C2 Cab. Completely non functioning, following a winter of sitting outside in the rain, snow, frost etc (the car, not me). This has meant that the pool of water that has collected in the driver's side footwell (leaky roof) and I think this has cooked either the spoiler relay (part no 96461814200) or the control module itself (part no 96461821200). The relays are under the driver's seat as this is a 1990 RHD car (later models have these components up under the dash).
My question is, how can I test the relay, and then the spoiler module? I can't hear the relay clicking, so am assuming I need to replace that (new one on the way to me).
But what about the spoiler control module? How can I test that? At the moment, the warning light comes on at 50mph to indicate failure of the spoiler raising, and stays on until standstill. Does the spoiler control module send the failure signal, or is this more likely to indicate that the control module is at fault?
Any help greatly received as ever ...
Jeremy.
PS: Anyone have a spare spoiler control module they would be willing to sell??
If the controller sat in water without being operated, then was allowed to dry out before power was applied, the problem could be that the controller relay contacts have corroded / frozen shut. If you pull the cover off the controller, you'll see two box-like relays on the corner / pin end of the board. They have tiny contacts, similar to old fashioned ignition points. Check to see if they're frozen. You can clean them by inserting a folded piece of VERY fine sandpaper and wiggling it around a little.
If power was applied to the controller before it dried out, I'd suggest you just get the charge card out first and save yourself from troubleshooting any further, thus minimizing the frustration. (Does it sound like I went through all this once?)
