964 accelerometer question
#31
Very interesting guys
thanks for Charing
I go and check mine ASAP , I booked a track days with artificielle wet conditions with an inctructor, I hope to learn a lot from my C4 ,
in fact if I disconnect the accelerometer do I stop the system from transferring power to the front ?
thanks for Charing
#32
#36
C4 requires two sensors for lateral and axial.
C2 requires one sensor for lateral only.
I was under the impression that tiptronic cars only came in C2 flavour so would only have the one sensor?![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Anyway I pulled the trigger on two of these, will install as part of my centre console delete once I've sorted my water issue!
#38
Hi everyone
I want to quickly share with you some experiences I gained with the JDS sensors:The longitudinal accelerator controls the braking system. Compared to the original equipment I can feel that the ABS kicks in a little bit earlier when I break hard, especially on slippery roads. The sensor seems to be more sensitive.The lateral sensor seems to be more sensitive as well. I can feel it when I drive quickly through narrow curves. The sensor activates the axis breaking early (there is a yellow light in the center console) and as a consequence, understeering seems to be much less an issue as usually with the Carrera 4. From what I have experienced so far, it seems to be gone and driving is totally balanced (also no oversteering). I will continue to observe and confirm the experiences made so far.
Cheers
#39
#41
For the comment above- yes it's very evident on the track, but really because tracks are almost always bumpy in hard braking zones...and its on bumps where it shows it's worth most clearly...
Anyway, I'm a fan.
Anyway, I'm a fan.
#42
