Head Gasket Check
Head Gasket Check
Just got motor rebuilt and new exhaust with magniflow muffler. After a couple of sessions I noticed the car got significantly louder, especially at idle. Seems to have plenty of power, so I checked manifold, exhaust, and muffler for leaks and can't pinpoint any. Changed oil and the magnetic drain plug was metal free after 3-4 hours of track time. When I start it, it sounds like a car with a hole in the muffler.
Mentioned this to my engine builder and his biggest concern may be blown head gasket. My question is how to test for a blown gasket? I have no compression test equiptment and my builder is out of pocket at this time.
Any thoughts? I was going to pull the plugs this weekend to see what that may show me.
Check the O2 sensor....mine had rattled loose and unscrewed itself from the Cat.
Hope it's nothing major?!
Super Duper Moderator
Could it just be louder due to the new muffler you are not used to? Can you swap back on the exhaust you had before and see if it still sounds odd.
Marc
Marc
As you describe the sound, I would like for misfits in the exhaust system. Maybe something virbated loose their (or indeed O2 sensor vibrated loose due to corrosion or something). Otherwise headgasket or something, but thats rather odd since rebuild would imply new gasket.
if its a 964 then there is no coolent in the car its air cooled. if it is not louder when you start it then i would say its not a head gasket as the head would expand as it got hotter make a even titer seal and less noise. if it makes it when it is warm then i would look at the expanding bits.... exhaust gaskets....
Nothwithstanding the humor above re: coolant, the "head" (actually a CE) gasket would be a near impossibility here. Can it get screwed up during assembly? Sure. But you'd know the first time the engine fired.
Now, onto diagnosis. Is the sound in time with all six exhaust pulses, or very rhythmic and noisy on only every sixth pulse? If it's the former, the only place it could be is the muffler. If the latter, everything from the exhaust port on downstream to the muffler.
