sunroof and windows won't open (solved... #4 fuse was burnt)
Hi Gents,
No idea what happened. My g/f took the car out for a few hours, and it hasn't worked since.
The sunroof is not closed quite all the way, there is a few mm gap in the front.
Windows won't go down. Both sides.
I found that there is only one fuse for sunroof - it's fine.
There are separate relays for windows and sunroof. I switched some around (for sunroof) and it still didn't work.
What could it be? I don't think it's possible for all 3 motors to burn out.
Any ideas?
Any ideas?
You are aware of the emergency closing mechanism for the sunroof? If you un-zip the headliner right above the back window, there is a crank where you can close the roof... (just in case...)
No answer for the windows.. sorry.
nope, US
Didn't know that, will do that right away! Luckily it never rains in SF Bay Area
