What are used 102mm mahle cylinders worth
Working on my rebuild options
I've got a complete set of slip in (107mm)
Mahler cylinders that have been bored out from 100mm to 102mm
With nikisil lining.
Appear to have good specs and bores look clean as well.
Not sure what they are worth if i sell them as a set.
Thx
Mike
Thx
Mike
What about the pistons? They are matched, even more so after they have been run.
You had a set of stock cylinders, had them bored and then recoated?
Slip in 107mm? That is your new replacement set?
I have seen used pistons, pins and cylinders all over the price map.
They are worth what some is willing to pay, but until we figure out what exactly you have or don't have they are not worth anything.
the jugs are from a race engine where the PO had Ross pistons in there.
the PO pulled the car off the track because of piston slap.
when i disassembled the engine -- the ross pistons had some scuffing on the skirts and along the ring landings.
the cylinders look and measure perfect. Exact origin unknown -- they are 102mm bore with 107mm slip in exterior. Nikisil,
either 100mm bored to 102mm or maybe 102mm 993 cylinders.
I'm planning to ditch the ross pistons and sell the mahle jugs.
just don't know what to ask for them
mike
mike
