964 Forum 1989-1994
964 Engine Compression #'s
Old Jun 30, 2011 | 02:30 PM
txhokie4life's Avatar
txhokie4life
Default 964 Engine Compression #'s
Will be testing a 91 964 engine this evening before
starting the work to put into my track car.
It's not an engine I plan to tear down, I have a race engine
rebuild in progress.
Just checking the health of this interim engine.
I'm new to the air cooled engines, I've found that there is
usually a range for each type of engine that I've tested in the past.
What sort of #'s should I be looking for with compression
and leakdown tests?
thanks,
mike
Old Jun 30, 2011 | 03:29 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
JMHO,....
Do a leakdown test, thats FAR more useful than compression testing as it not only provides real-world results, but allows you to pinpoint the source of any observed cylinder leakage.
2%-4% is like new
5%-10% is fine
10%-15% is something to investigate
20% or more is a problem.
Old Jun 30, 2011 | 04:53 PM
txhokie4life
Thanks Steve
I'll let you know what we find out.
Mike
