A/C compressor troubles
Thanks for everyone's help on the CCU - the CCU and servos work.
Here's the funny issue (now). When the temp. is hot (97F+ and sunny), the A/C only works intermittently and today I was sweating my rear off. The compressor will cycle and sometimes it's cool, mostly it's warm.
When the temp. cooled down this evening (80F and not sunny), the A/C works great and the compressor stays engaged. I can actually cool off inside the car and get comfortable.
Now from what I've read from here and Pelican, there's a chance the R12 level might not be up to snuff and the pressures are incorrect. I mean yes, the compressor does engage so I know that it works in that capacity. But without working A/C during the daytime, the 911 is near-unbearable to drive.
Any advice? I've the correct refrigerant level figures, but what are the correct high/low pressures?
IHI KING!
Do you have access to the factory service manual? It has a refrigerant pressure table for both R-12 and R-134a. The desired pressure varies depending on the ambient temperature.
My dad took it by the shop today and it turned out the compressor is leaking. Pity. So a new compressor and condenser (from what I was told, I may be wrong) are being installed and the system converted to R134a. It would make top-offs a breeze as R12 is becoming more expensive (and requiring licensing to purchase).
So we'll see how cold the A/C is tomorrow around noontime.
