oil light problems 964
Hello everyone, is a bit of time, when I'm in traffic with my 964 with the oil temperature hot I often I turn on the lamp oil for 5-10 seconds, the oil level is OK, there's someone who could help me? Thanks to all.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Have you made sure that you oil cooler fan is operational?
Also, you might want to make sure that the oil cooler is clean and free of any debris which may be inhibiting the air flow through the oil cooler.
Also, check the piping running down the right side of the lower body - that's the oil line, it should be HOT - otherwise you may have a bad thermostat.
