91 C2 Cab top won't seal
The top folds up and down with no problem, but when raising the top to close it, the top reaches the winshield top brace as usual but the motors that usually seal the top do not seem to engage. So the top just sits there with a 2 inch gap between the top and the winshield brace.
The top folds and falls into place just as it always has - with no unusual noises. I'm looking for possible causes, troubleshooting and of course the best way to fix it.
Any suggestions are appreciated!
Steve
Steve
yes the rear window is always unzipped when I operate the top, I learned that the hard way.
The top operates normally to the point where the leading edge is about to lock. Then it does not lock. The problem seems to be with the motors that lock the top to the windshield frame - they do not seem to work at all. Any ideas?
Steve
Steve
Steve
Steve
Hope it is that simple...........
Check the microswitches on the convertible mechanism - transmition. Most likely, the upper one is in the wrong position and to early gives a signal that closure of the roof is complete. If this does not happen every time probably, the cause is loosen the three (or four) screws securing carbio or central screw on transmition.
Burgled
I have owned my car for 8 years and have never unzipped the window and never had a problem with it. I gotto say tho that my top stays down about 9 months of the year and maybe only raise it a few times a year to wash the car sometimes.
Thanks for the microswitch info, I'll look into that asap.
As for the rear window unzip question...Porsche recomends the rear window be unzipped to remove the tension on the roof as it closes. I've been told by more than a few cab owners that it's especially important in colder climates where the cold can cause the window to crack or spiderweb. I had to replace and repair the cab motors a few years ago when they broke from the mounts (@ $2k) and I was told that this is often caused by not unzipping the window and/or stopping and starting the roof mid cycle. So...it takes me 5 seconds to unzip it and now I ALWAYS unzip it here in NJ USA.
91 Cab top won't lock - details
well I opened the panels on the passenger side and the top microswitch does indeed get depressed upon closing. I checked the electrical connections and all look clean and secure. I've included 3 pics - the roof as it looks after going through the complete close cycle; the crank/transmission in the open; and then in the closed postion. In the closed postion, you can see the top microswitch is fully depressed as I believe it should be.
If you folks have and other ideas let me know otherwise it's off to the repair shop with it.
I do appreciate the help
Steve
Steve
Steve
Steve
Hi All:
Okay I know this may sound a little strange but try disconnecting the battery, wait 30 seconds, reconnect the battery and then try cycling the top again. I have my rear top transmissions disengaged so that the top can manually operated but I still use the electrical top locks. Every third time of cycling the top the lock motors cease working. Its almost like the system is in some sort of fault condition from the previous operation. By cycling the battery it seems to clear the fault so the top lock motors work again. This won't solve your overall problem but it may help get the top locked down. Of course getting the top to open again may cause all sorts of other issues if the top lock motors don't cycle but the rear transmissions try to operate. I will be watching this thread with interest because I intend to get the top back back to fully automated form this summer.
The upper microswitch is definitely too close to the roof rack, just loosen the screw and slide the black plastic to the left, then close the roof.
You have precisely adjust the location of upper microswich (open and closed), because roof should stop just above the window, and then locking motors close the roof. When roof is closed upper microswitch schuold be touched by roof rack. Locking motors have microswitches too.
