HEAD GASKET
my engine on early 89 964 c4 with 3.6 being rebuilt mechanic asked if i want the head gasket installed or not said i would lose some compression.i am wondering with the arp studs that he installed allowing the heads to be torqued a little tighter should i still install head gasket and sacrifice a little compression or not?and how much compression loss would we be talking about enough to notice?
What's the formula--1 point of compression is 5HP? Anderson had it in his book from the dyno work Woods did back in the Garretson days.
In any case, as wellcraft mentioned, the CE (it's not a head) gasket doesn't change combustion chamber volume.
well i went to go meet him and see it and he put the gasket in for me. he did a nice job of cleaning the heads glass beaded them to get all the grime off.then put them in parts washer and here is what he came out with.New valve guides installed and new intake valves waithing to be put in.
