964 Forum 1989-1994
Fire extinguisher
Old Mar 24, 2011 | 03:58 AM
ACSGP's Avatar
ACSGP
Default Fire extinguisher
Just to share, ordered this from Rennline:
http://www.rennline.com/Fire-Extingu...info/FE02-H3R/
Got it in black to match the carpet. Quality is very good, and Rennline are quite dependable.
Since they were shipping to Singapore, Rennline discharged it fully, and sent it by UPS, so no issues shipping international. Just find someone in your country to charge and maintain the extinguisher.
Old Mar 24, 2011 | 09:20 AM
power_up's Avatar
power_up
Interested. it come in empty bottle?
Old Mar 24, 2011 | 10:49 AM
Laker's Avatar
Laker
So you have two choices on filling?:
MaxOut™ dry chemical fire extinguishers have a proven track record in extinguishing the types of fires likely to occur in an automotive environment. Models MX250C, MX250B, and MX250R utilize a specially fluidized and siliconized mono ammonium phosphate dry chemical. All MaxOut™ models effectively smother and break the chain reaction of fires involving flammable liquids and pressurized gasses, and will not conduct electricity back to the operator. MaxOut™ models MX250C, MX250B and MX250R are also highly effective at stopping fires of common combustibles like wood and paper. Great for marine or residential use.
or
HalGuard™ is no ordinary automotive fire extinguisher. It contains Halotron 1®, electrically non-conductive "clean" extinguishing agent that rapidly turns into a gas. Halotron 1® has passed extensive testing by Underwriters Laboratories, and meets FAA requirements. It can be found on commercial aircraft, and is used by airport fire fighters and on the flight line."
Have you lined up a place in S'pore to fill it?
Old Mar 24, 2011 | 10:26 PM
ACSGP's Avatar
ACSGP
Yup, done and dusted. Went for the MaxOut, which is in reality what is generally called ABC powder that should last longer in a hot environment like a car's interior.
Old Mar 25, 2011 | 12:24 AM
ACSGP's Avatar
ACSGP
They fully discharged it before sending it to me. Cost me SGD9 dollars to refill it in Singapore. I'll go back for annual inspections.
Old Mar 25, 2011 | 01:11 PM
power_up's Avatar
power_up
Thanks. I hv to find any places can fill locally.
Old Mar 25, 2011 | 01:12 PM
power_up's Avatar
power_up
Really thanks for the info and explanation.
or
