Another won't start thread
Richard,
i assume that if i have spark the dme is getting a signal from the CPS to fire?
Couldn't tell the colour of the spark but i will check again.
Ray,
I am beginning to think the gas (petrol) may be bad but it is a full tank and it only sat for a month or so in -20 weather. I might drain it and it and use it for the lawn mower.
Ray,
1 Post
It's common for a failing coil(s) to send a spark, just not one strong enough to ignite the fuel-air mixture. A strong spark will be blue; a weak spark will be yellow, red or orange. While one of those week sparks can sometimes set the mixture alight, performance will suffer. I've never known this "blue spark" test to fail in diagnosing a bad coil.
Of course, with two coils and the 964's ability to run on just one, this diagnosis isn't the most accurate. I've never tested it on a dual-coil system.
Frank,
Any luck?
I've been looking through my notes and have a few more bits that may be helpful. Also, you have a PM.
Hope you get it sorted.
Hard start or stalling / Engine will not start
Any luck?
- engine temp sensor
DME plug test
connect ohmmeter test leads between terminals 45 and 30break (infinit Ohm)
0*C = 4.4 - 6.8 kOhm
15-30*C = 1.4 - 3.6 kOhm
40*C = 1.0 - 1.3 kOhm
80*C = 250 - 390 kOhm
100*C = 160 - 210 kOhm
Short-circuit (0 Ohm)
In the event of a break the system uses a fixed (warm) setting
which means there is no cold start enrichment and, therefore, cold
starting problems.
test sensor plug
In cold state, no engine pick-up, too lean, and engine stops.
No effect if engine is at operating temp.
similar
- idle speed contact (idle micro switch) - ground short or break
dme plug testthrottle switch plug
connect ohmmeter test leads between terminal 52 and 24
bridge ground to terminal 30
throttle closed <10 ohms
throttle open (> 1 degree) infinit ohms
connect ohmmetter test leads between terminals 1 and 2
can of "quick start", but doesn't seem to make a difference.
So now i'm thinking it's a spark problem? It's frustrating because it was running fine before i put it away for a month. And i didn't touch any of the ignition, intake, fuel components - all i worked on were the PDAS lock seal in the transmission.
I've got the bbq cooking the meat slowly so while the family is distracted i'm going to sneak out to the garage and check what dfinnegan suggests.
thanks again for all the help guys.
F
F
So checked the temp sensor, idle speed switch (and WOT switch too since it's on the same connetor) and all appear to working peroperly.
HOwever, when cranking it tonight one of my daughters was observing and noticed something dripping in the engine bay. Turns out my oil is way overfilled - it was coming out of the fill tube (leaking past the big yellow screw cap).
Now i keep my oil full when warm and last time i filled it up it was -20-ish. Now it's +5-ish (that's celsius btw) could that affect the volume of the oil? I didn't think oil would expand that much over a 25 degree temperature range.
the other question i have is could that much oil cause the engine not to start? I pulled the ISV and it was clean, and I pulled a couple of the upper spark plugs earlier and they were clean too, but maybe i should pull a couple of lower ones to check for oil in the cylinders? I have had too much oil before but it just idled rough - never a no start situation.
Indy, i think it's too rich to run as i have gas leaking from the exhaust gasket at the cat to header. But maybe this oil thing is the culprit. Going to pull the manifold when i have time and check it inside out.
Do you use the blanket technique to speed things up?
Even in 30ish C weather it is a good 15-20 mins of idling.
so if just cranking the engine is it possible to displace oil from the engine to the reservoir such that it would overflow?
Still curious if too much oil would lead to a no start condition.
SML,
I don't use a blanket, let it idle to warm up or anything, i just drive it. My daily commute is 20 to 30 minutes and the engine usually reaches normal operating temp after about 10 minutes even when it's really cold. I don't like to let things idle too long - i'm concerned about insufficient oil ditribution as the oil pump is running slowly (you could say the oil pump is "idling") and the oil is thick and cold.
SML,
Well cleaned out the manifold and there was sludgy WATER in the resonance cross tube. Collects there from condensation because it sits lower i guess? (the manifolds actually bend up from that tube connection so there isn't anywhere for it to drain.)
I'm also thinking my oil overfill might be petrol from the injectors leaking past the rings and filling up the oil tank as the oil has a slight gasoline smell to it. If i have time i'll being draining some oil tonight to check it. Is gasoline lighter than oil?
Got under the car and pulled off the lower panels (center cover and fuel pump cover) as i had those off to get at the tranny seal. I did find the flex part of the return fuel line to the bottom of the fuel tank had a big kink but given the dirt in the kinked part i think it has been that way for a while. But if it is new it might have restricted the return of fuel to the tank and caused the engine to super-flood with fuel?
I've tried to remove the kink and next i will pull out lower spark plugs to see if fuel comes out of the cyulinders and also to check condition of plugs.
