Oil cooler options
Oil cooler options
just starting the slippery slope of planning to turn my 91 C2 into a part time track weapon. Not planning anything too radical, just RS approach, I.e fairly standard engine and focus on removing weight and improving handling. The car will be used at Sepang F1 circuit in Malaysia so we are talking seriously HOT track temperatures. The standard cooling solution is very unlikely to be able to cope so just seeking views on options of adding a second cooler or something aftermarket... Any views ?
here's mine( a Setrab I'd have to look up the #) w/ AC, the hoses from the other side go into the 2 I/O ports at the front of the cooler. Alternately you can put a stock cooler there but the plumbing is harder because the I/O ports are on top and harder to get too.
Like Bill Said - for use on the track you must have a second oil cooler or your temps will easily reach the 10:00 position which is too hot. You really want the temps to stay around the 9-9:30 position wich is around 220 degrees F.
I have a setup just like Bill's, but used the largest Mocal cooler that could fit in the space. I have some pics located at the following url you can take a look at. I had a smaller mocal originally fitted (left over from my 993 setup) but it didn't provide enough cooling, so replaced with a larger Mocal and the cooling is much better.
https://picasaweb.google.com/lh/sred...YgB&feat=email
-Skip
-Skip
