964 Forum 1989-1994
Part for 964 windstop
Old Mar 9, 2011 | 12:53 PM
lvc2's Avatar
lvc2
Default Part for 964 windstop
One of the arms which goes from the windstop screen to the intereior side of the car is broken.
Does anyone know where to get a replacement or have any ideas how to fix this?
Ray
1991 Cab
Old Mar 9, 2011 | 01:13 PM
velocitylover's Avatar
velocitylover
Is this what you are looking for?
http://cgi.ebay.com/ebaymotors/NEW-P...Q5fAccessories
Old Mar 9, 2011 | 02:27 PM
lvc2's Avatar
lvc2
Thanks for noticing that. I checked and it is for the supports on a sun roof wind deflector.
Ray
Old Mar 9, 2011 | 08:42 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Pelican sells them for $7 each. http://www.pelicanparts.com/cgi-bin/...FILTER_TOOL=ON
They are easy to replace. You remove a phillips screw near the front of the sunroof track, this releases the bottom portion of the lever. The top portion is held on with a simple rubber bushing. Once you start on it, you will see its easy. Perhaps 15 minutes to do the first time, less than 5 minutes for subsequent ones.
Old Mar 9, 2011 | 11:18 PM
velocitylover
I just re read the first question and based on your signature I figured that you are talking about a cabriolet screen, not a sunroof part - sorry, but maybe one of cab owners can chime in...
Old Mar 9, 2011 | 11:28 PM
windblown's Avatar
windblown
I had a similar problem on a wind deflector I purchased. I replaced the broken arm with a piece of thinwall steel tubing. Hack saw, a little grinder work, some twisting in a vice for the angles and a coat of satin black and it works prefectly.
Old Mar 19, 2011 | 02:15 AM
lvc2's Avatar
lvc2
Thanks. I got a silicon formable mold and formed it around the good one. The resin replacement looks good. Will try it tomorrow.
Old Mar 19, 2011 | 03:34 PM
windblown's Avatar
windblown
Please post up your results, I would like to see what you come up with.
