Cheap way to oil leak (oil line from oil filter to engine)
Hi guys!,
I'm changing all the gaskets of my engine (valve covers, chain covers, chain springs) and I found a small leak from this oil line, I will change the oil line from filter to thermostat housing and the 2 ones which goes from thermostat to the radiator.. But this one was in good conditions so I found this way.
I put some Loctite 5920, the same which i use for gaskets.. And that's the result;
