964 Forum 1989-1994
New brakes! **Caution, Brake Porn!***
Old 03-03-2011, 09:42 PM
Dave White
Dave White's Avatar
Default New brakes! **Caution, Brake ****!***
Just got my car back from my latest battery of re-freshening and upgrades. I didn't really need more brakes, but figured one step up would be nice "just in case" I decide to do more track work. I needed new rotors anyway, so decided to go the plus one route. 928S4 fronts(304mm) and 993 rears with cross drilled rotors all around, painted red, of course! I'm really happy with how they turned out! Check out my custom decals...
Major thanks to Bill Verburg and his chart on brakes
Old 03-03-2011, 09:59 PM
sml
sml's Avatar
Looks good.
What was the total cost?
Is it basically calipers, rotors & some sort of bracket?
Old 03-03-2011, 10:12 PM
Dave White
Dave White's Avatar
Got the brakes used on ebay for about $700 total, hoping to recoup as much as possible from the sale of the originals(see other thread!), plus rotors at another $350 or so, adapter front brackets are going for $200 at Rennline, but I believe mine were used parts the shop had, plus paint and decals that most would do themselves. The rears don't require brackets or even different rotors, but I wanted cross drilled. I was having all the wheel bearings and CV joints done, so I had the shop do it all while everything was apart.
Old 03-03-2011, 10:24 PM
sml
sml's Avatar
So are the numbers something like ...
new parts:
front calipers $700
front rotors $350
adpater $200
sell old parts:
front calipers $300
upgrade cost = $950
but my rotors need replacing so it is really only $600
Old 03-03-2011, 10:41 PM
Dave White
Dave White's Avatar
Sell both sets of calipers as the 993 rears have larger pistons(more clamping force) to help compensate for the bigger fronts. So you may be down around $300. If you went with standard rotors, you could do better on pricing. Not a bad upgrade for the money, as long as I can sell my original calipers. By the way, that was $700 for BOTH sets of calipers.
Old 03-03-2011, 11:12 PM
Jonnygo1
Jonnygo1's Avatar
What about upgrading to a 993 Master Cylinder?
Old 03-03-2011, 11:39 PM
Dave White
Dave White's Avatar
Not needed for a C4. I did change out the proportioning valve to the 40bar used on 993's.
Old 03-04-2011, 12:02 AM
sml
sml's Avatar
new parts - front & rear:
front & rear calipers $700
front & rear rotors $350
front adpater $200
sell old parts:
front & rear calipers $300
upgrade cost = $950
Old 03-04-2011, 11:57 AM
Boeing 717
Registered User
Boeing 717's Avatar
Whered you get the carbon fiber decals???
Old 03-04-2011, 03:35 PM
sml
sml's Avatar
Edit ... missing critical RS29 brake pads ... So are the numbers something like ...
front adpater $200
critical RS29 brake pads $600
sell old parts:
sell used RS29 brake pads $300
upgrade cost = $1250
does this look about right?
Old 03-04-2011, 03:53 PM
Bill Verburg
Bill Verburg's Avatar
Are you using 993 front rotors?
Old 03-04-2011, 11:05 PM
Dave White
Dave White's Avatar
They actually are older 928s4 fronts. Since those had the raised Porsche letters and horizontal lines, I had those machined off to get the flat surface for the decals. Thanks Bill for all of the info you have posted on this subject, this project was a direct result of your unwavering help to the community.
I went with the 304s as they are much lighter than the 322s, and these are probably overkill enough, bigger isn't always better. I will probably never need all of this braking power, but my brakes will probably last forever as they don't have to work to stop the car at any speed!
The decals I got from an online company that I saw on another thread here on Rennlist. I had issues with them and will not post their name and support them. I had to file a pay pal complaint to finally get the product. After the fact, I googled them and found out many people had filed complaints against them, I usually research first but got lazy.
Old 03-05-2011, 10:46 AM
Bill Verburg
I've never seen drilled 928S4 rotors, have you got part #s?
Old 03-05-2011, 11:04 AM
Dave White
Dave White's Avatar
Got them from your post on Pelican, both rotor sets are 968 M030 I believe. 965 351 041,2 01 fronts, 951 352 041 91 rears. Here is the original post which tells you all you need to make this project happen:
http://forums.pelicanparts.com/porsc...rs-brakes.html
It all just bolts on!
Old 03-05-2011, 11:18 AM
Dave White
Dave White's Avatar
Sorry, misread this to read calipers. 968 M030 rotors all around, 928S4/993 front calipers and 993 rear calipers.
Quick Reply: New brakes! **Caution, Brake Porn!***
