964 Forum 1989-1994
Removing Flywheel
Old Mar 2, 2011 | 06:22 AM
cobias1's Avatar
cobias1
Default Removing Flywheel
Other than a possibility of stripping bolt heads..is there a real reason not to use an impact gun when removing the flywheel bolts ? Reason I ask is that I seem to have better luck using the impact on low while removing bolts from this engine than not using it. thanks in advance for any comments.
Old Mar 3, 2011 | 08:31 AM
3blackbirds's Avatar
3blackbirds
Yup, put the impact on low, give them a light touch, they'll come right out.
Old Mar 3, 2011 | 09:32 PM
scped's Avatar
scped
I've only done this a few times, but have never been able to remove the flywheel bolts without an impact gun
Old Mar 4, 2011 | 11:15 PM
cobias1's Avatar
cobias1
Thanks guys for the little extra en"courage"ment...got them off this afternoon and all the bolts looked the same length as they came off so that was a good thing..everything turned out well and maybe on the next day off I can get on with cracking the case...Thanks again!
