Will these wheels fit?
hey guys will wheels with an offset of ET45 front and ET49 rear fit my stock C2 or do I need spacers?
What width?
Dont need diameter btw. |
They are 8s in front and 9s out back....sorry I forgot about that tiny detail
should fit. I think that what mine are.
The general rule is ET 45-60 on the front and less than ET 59 on the rear. |
If you want a quick yes or no .. then wait for replies.
OR .. If you'd prefer to understand the dimensions yourself then read this ... https://rennlist.com/forums/964-foru...el-offset.html My old cup wheels ... Front 7 ET55 Rear 8 ET52 - really needs to be further outwards. My new OZ wheels .. Front 8ET50 - this is fine. minor clash on the inside at full lock but no real problems Rear 10ET40 - this requires negative camber and a slight fender roll With these benchmarks, measuring your own offsets & clearances, as well as the calculator then you should be able to get a good feel. |
Thanks for the help guys....
