UK heads up - Porsche prince seat on Ebay
Hi Everyone,
Just a heads up that my Porsche Prince seat has gone onto Ebay in the UK. It was difficult enough finding one when I was looking.
Does anyone have a good booster seat solution as the one I'm trying at present is not a good fit?
Cheers,
David
Cheers,
David
I found a cheap $13 booster seat (no back) and used a Dremel cutoff wheel to trim around the base so it'll fit in the rear seats. Can't remember for sure but it's either a Cosco or Graco brand and I found it at Target... which might not help out you guys from UK.
Thanks Guys,
The Halfords booster that I got didn't fit well at all and I'm worried that if I cut off too many bits there won't be much left as it's hollow. I was wondering whether to just carve some polystyrene and cover it. Can't be too difficult can it?
Cheers,
David
Cheers,
David
Try the Maxi Cosi Rodi SPS (not the other variants, the SPS has the narrower base). Fits fine in the back of the 964, and used to be available from Halfords in range of colours. Have yet to find just a cheap base that fits in myself, but you can remove the back on this if you need.
