964 Forum 1989-1994
CCU Fan
Old 01-09-2012, 03:42 AM
milutintin
milutintin's Avatar
I guess you need to change the fan. For your info my modified fan is still working ok.
Old 05-29-2012, 11:19 PM
dutchcrunch
dutchcrunch's Avatar
Default fan sticking needing a nudge.
i fixed mine, do not use oil you need grease oil is too slippery. grease works better as to when the fan stops it will stop inbetween the magnet fields and not in the middle, which requires a nudge to start. i used that red and tacky . did 100 starts and stops and it worked like a charm. on the other hand 3 in 1 oil would cause it to stop in the wrong place and need nudge. maybe 1 out of 10 times.
Old 05-30-2012, 08:40 AM
milutintin
milutintin's Avatar
What grease did you use? Where did you put the grease?
Thanks,
Old 05-30-2012, 07:07 PM
dutchcrunch
Default grease
lucas red & tacky # 2 got it at napa auto parts comes in a big tube but some good stuff
Old 05-30-2012, 07:09 PM
dutchcrunch
Default grease
i put a dab on each end. about a 1/4 inch up worked like a charm.
Quick Reply: CCU Fan
