Wow! didn't know these where out! these V1s should be just as good for street, as I had V1s on a few of my Vws, and they are good, with the quality. Just wonder how much they are here!
I think the max drop should be similar, KW mentions 320mm wheel hub center to fender edge. TireRack has a 225-40-18 with a diameter of 637mm so I think the fender should just about be at the top of the tire.
Would be interesting to findout what difference in drop compared with the Clubsport and the V3s.
I just looked at the V3 manual that is dated 10/26/2010 online. It has the same 320mm info for wheel hub center to fender. I talked to the KW guys a good bit and they said on a 964 the V1's are basically V3's just without the damping adjustment. They use the same springs 170lbs front / 450lbs rear and I think the shock bodies are the same.
