Door alignment?
Can the door be adjusted?
I think from old VW cabriolets I have owned you should be able to adjust the glass in various different ways. If the door card is removed, the window will normally have several options for adjustment to improved and create a secure fit.
However my experience on old VW convertibles may not apply, but the trip from Stuttgart to Osnabruck's Karmin factory isn't far so they may have shared similar ideas on this.
Here is a good link on Pelican.
http://forums.pelicanparts.com/porsc...ht-adjust.html
and another
http://forums.pelicanparts.com/porsc...w-problem.html
Adjustments might be the same for the 964.
John
