First gear "pops under pressure"
I searched around and could only find issues of the gear popping out without the clutch pressed in, basically my problem is when in first gear in higher rpms (3.5k-5k) and I go to shift into second when I push the clutch down the gear shifter almost jumps into second, does anyone else experience this?
IHI KING!
I hope its not that drastic but that's the first idea that came to me. I would first check your shift linkage to be sure its not something simple.
http://en.allexperts.com/q/Mazda-Rep...ear-manual.htm
Funny enough I thought of posting about this issue earlier this week. Mine often pops out of first gear when there is a lot of pressure. It never happens when the clutch is out so I don't consider it an issue but it definitely acts like it is trying to shift itself into second when I depress the clutch.
![Wink](https://rennlist.com/forums/images/icons/icon12.gif)
I searched around and could only find issues of the gear popping out without the clutch pressed in, basically my problem is when in first gear in higher rpms (3.5k-5k) and I go to shift into second when I push the clutch down the gear shifter almost jumps into second, does anyone else experience this? ![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
I realize that and was defending my car from the pink Ferrari comment
in your other post.
but in all seriousness. used cabs tend to have been driven less hard by the POs, so I'll take that as a plus.
Hope you get this sorted,....I find this issue interesting.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
I'd put my money on worn engine mounts.
I changed mine recently to RS engine mounts from pelican and the difference in ease of shifting and no hopping out of gears is amazing.
Might be worth investigating.
