Scantool and the Tiptronic
hi
thanks for the reply...
I'm not 100% sure it's my ecu just yet.. reason I say, is that I used a generic cable and the durametric software to connect to my tip ecu and that's how I managed to pull the 21 code... but for some reason, the durametric (vers 5) wouldnt connect to me dme and I wanted to see if my engine ecu had any errors..
Tonight I was able to verify that there are no errors on my engine ecu using my friends scantool, but for some reason it wont connect to my tip.. in fact, the 3 or 4 times we have used his scantool, it has never been able to connect to my tip..
Can I ask where you found reference to the #21 error usually being related to an ecu fault? If it is, then I am OK with that.. as I can buy a second hand one (hopefully not also a dud) and all my problems will be fixed (till the next one)...
