Stupidity admitted
Stupidity admitted
Well I spent last night getting the car up in the air to do the starter change. I read every post I could find on the subject and felt I was well prepared for the job at hand. Everything went smoothly. Only took a few minutes to remove the dreaded top nut and the starter was shimmied out fairly easily. New starter went in just as easy even though the top nut took a bit longer to get started and tightened down. I went to re-install the battery cable and the only hiccup was that I grounded the wrench on a piece of metal mistakenly causing sparks.
The moment of truth... I turned the key and............. only a click. WHAT THE HECK? Did I get a bad starter? Did grounding the battery cause some type of damage to the electrical system?? After sitting there thinking about it awhile, I figured I better check the grounding cable from the starter to make sure it didn't have any corrosion. Raised the car back up and then lo and behold my problem. I only attached one of the positive cables routed to the starter. I felt like such a bonehead. Hooked it up, dropped the car, reattached the battery (this time without causing any sparks) and it started immediately. Satisfaction achieved.
Next, spark plugs........
