blower motor fixed
I found out my problem was the 25 amp fuse in the engine compartment fuse box. Blower would only work on blue dot, any attempt to go to red the dash vents would cut off, as well as no defroster. I did change the relay but forgot about the fuse. Anyway, heat and defroster works. Now I just have to find out the deal with my rear spoiler.n
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I've had same problems lately. I read a post the other day that said Porsche issued an update to go to a 30a fuse. Would like to confirm that.
Spoiler issue was a bad controller, which is located under passenger seat. I replaced the transistors, but I think it was one of the relays that was bad. Still working on it, but a used replacement controller solved everything.
Mine would deploy only and not retract. I think the problem is one of the two relays on the board is fried. I still think something is binding on yours. Have you tried full operation with drill connected to the cable? No damaged teeth on the blade gear? A little grease?
You can bypass the controller and check the motor by disconnecting the wiring and supplying 12v directly to the connector pins. Reverse to check full operation.
Hotwire? How do I do that. Another question, how do I disable the spoiler completely until I get this issue solved? Hate riding around town with the spoiler halfway up.
I don't know about your year model, but mine has a push-together connector at the motor with offset round pins in it for + and -. If you have a battery charger, spare battery, or can run some test wires from the battery or any other "hot" source to the pins in the connector, you can actuate the motor. Just watch for direction of operation and reverse the test wires if necessary to first deploy, then retract the spoiler. If the motor is good it will operate the spoiler completely, and you'll know the controller is the most likely problem.
OP - I'm having the same problem you had with the HVAC only working on the blue dot.
I got a resistor from Pelican Parts, but I don't know where it goes.
Can you let me know where the resistor goes on the rear blower?
Thanks!
Thanks!
The ballast resistor for the rear blower is clipped into the left side of the plastic plenum pipe which runs between the blower and the entry into the heat exchanger. It's right opposite the triangular fuse/relay panel.
Regards
Dave
Regards
Dave
