Confirm Length Stock Rear wheel Studs
Thanks Ken, huge help. 45mm seems to be correct stock length. I just wanted to make sure. I was thinking of using 7mm spacers on the rear and wanted to make sure I got the correct extra length studs. I was thinking 52mm but as you mentioned 66mm might be better.
Dan
Dan
Is there a 52? I don't remember. I usually have stacked one or two 6-7mm factory spacers (OE rear from the a '68, which was my first 911 and ended up with a few extra sets over the years). So if a 66 was too long, no big deal with open ended lug nuts. Worst case, just whack off the ends to your spec with a grinding wheel.
