Fuse Upgrade from 7.5 to 20 Amps
The factory fuse for my horn is 7.5 amps.
The horn that I am considering for replacement needs a fuse of 15 to 20 amps. Can I simply change the fuse to a 20 amp fuse? Will all the wiring be ok, etc.
http://www.amazon.com/Wolo-Model-419...pr_product_top
The fuse is supposed to be the weakest link in the circuit. Your wire gauge should be able to cope with a higher amperage than the fuse otherwise it will melt and possibly catch fire before the fuse blows if subjected to too high a load.
For 20 amps you probably need at very least 16 gauge wire to be safe. No idea what size wire you already have but if it is designed for 7.5 amps you might be better off running a seperate heavy duty circuit with a relay.
