Cat bypass and motor mount installation pics
Some pics from my cat bypass/motor mount installation from a few weeks back:
http://picasaweb.google.com/kylejohn...ssMotorMounts#
Special thanks to Emmett aka Unkle here on the forum for saving me ~$100 by sending the pipe across the Altantic. Folks like Emmett are the reason this forum is so great.
I initially had more of a fuel smell after installing the pipe. After sending my chip back to Steve Wong to be reprogrammed with the bypass pipe option, I am pleased to report the increased fuel smell has gone away. I already had a cup pipe and I've noticed what seem to be slight improvements in power and throttle response. Combine that with a deeper, more aggressive exhaust note and I could not be happier. I am a definite fan of the cup pipe/cat bypass combo. Plus it will be great to eliminate the heat associated with the cat once summer rolls around here in Houston.
Ended up going with the Corteco 993 motor mounts from Pelican, part number 993-375-049-09-M270. So far, I am very pleased with them. As you can see, my original mounts were slightly past their prime.
And yes, I know I need to paint my rotors (next on the list).
...I initially had more of a fuel smell after installing the pipe. After sending my chip back to Steve Wong to be reprogrammed with the bypass pipe option, I am pleased to report the increased fuel smell has gone away. I already had a cup pipe and I've noticed what seem to be slight improvements in power and throttle response. Combine that with a deeper, more aggressive exhaust note and I could not be happier. I am a definite fan of the cup pipe/cat bypass combo...
When I purchased my SW chip I went for the 93 octane, cat-bypass chip...so I'm ready to go if the smell isn't bad.
I've been holding off getting a cat bypass because of the smell...didn't even thing about the effect a SW chip could have on the smell?
Others have described it as almost unbearable so it seems to vary from car to car.
Is imposible to change the down valve gasket if you don't eliminate the Cat?? Was it difficult to loosen the screws?
