New Wheels, Tyres, Fenders, Coilovers
but the bump steer is a separate issue, right?
Can you post a pic of your car at RS+5?
Thanks.
JIC Cross ...
I ordered 8kg & 11kg. Box said 8kg & 10kg and box didn't look opened so not sure whether the rear is 10kg or 11kg.
Reaching that height at the front, there is only another 5 to 10mm of drop remaining before the height adjustment perch hits the spring perch (the spring perch is fixed during height adjustment).
At the rear, it is only approx 5mm from the lowest setting. In hindsight, I would do the following before installing the rear coilovers, just to provide some extra flexibility if needed .... quote from JIC ...
Make height 10mm low rear suspension top of nut please remove and under the pillow ball upper mount has two spacer. please remove one spacer you should be able to low down 15mm more. please make sure when you remove nut use high pressure air gun. low pressure gun does not remove easy and make damage seal and piston. need remove nut quick possible. same with hold tight bump stopper and rod by hand.
@Daryl....I was surprised to find that I haven't taken a nice still shot of the 964 since I had the ride height adjusted to RS+5. Hopefully this track shot will do for now (even though I have just started to brake)
![](http://i32.photobucket.com/albums/d25/brksy16/Boxster%20trackdays/R10MB2.jpg)
Former Vendor
Glad you like the wheels! If there is anything you need next time keep me in mind.
I have plenty left if anyone else in interested! Please contact me. Thanks.
In my book bump steer is the adverse effect of the susension components actively changing the toe of the wheels. At normal settings the effect of the suspension on the toe is gradual. As we lower the car we firm up the suspension and change the angles of the control arms so the changes in toe are quicker and more obvious over the same bumps and depressions. That's how I understand it anyway. Personally, I found it was a one wheel hitting a depression in the road that produced the most pronounced sensation of the car trying to steer itself.
@Daryl....I was surprised to find that I haven't taken a nice still shot of the 964 since I had the ride height adjusted to RS+5. Hopefully this track shot will do for now (even though I have just started to brake)![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
